if you can, use SNTP service to get the time instead of the time from the cloud as for security, you need correct time. Time from IP cloud will be with the precision of - within a second for the most time.
Then why bother writing in every post? If the feature is useless or unusable it will die eventually. Just by opposing you are stirring up the interest, so there are other features in from the ‘/ip cloud’
I found 2 2011s that are running a ipsec tunnel between them. One of them… time is right. The other is off by a few hours and minutes. Both are using ip cloud. I don’t have admin rights on them, so I need to contact the installer.
FWIW I like IP Cloud, Time and DDNS. Single click convenience. Believe it or not but there’re home users here who base their decision to get an Asus router on it having free asuscomm.com DDNS.
