IP Cloud in v7 not working
Dear all,
Hope you are fine and doing well. it is stated that I have tried many times make filter rules.but Mikrotik not accessible with sn.mynetname.net in v7. But in v6 I have no problem just enable IP Clod DDNS and it is accessible remotely.
please see the attachment
Thanks & regards
On your screenshot in the box it states “Router is behind a NAT. Remote connection might…”
If you have a NAT “upstream” (your ISP) that you cannot control, inbound connections might not be possible, nothing related to 6.x or 7.x
Your rule is exactly like mine, I run 7.5 at the moment.
IP Cloud only takes care of the “dynamic DNS” part, nothing more.
It dosen’t metter. my Rb750 Gr3 is also behaind the and IP Cloud is working.
Suggest any other this if any
What would you do with Cloud services if the Rotuer is behind an external NAT? You will get a DNS points to your ISPs NAT.
Without a public IP Cloud would not give you much.
The rule you show is only related to the IP-cloud part, nothing to do with DNAT for making the actual inbound connection to a server/service you host.
So, if you resolve your XXXXX.mynetname.net how does it compare to any of the IP-addresses on your box ?
If you don’t have any hits on that “input” UDP/15252 rule and you are sure of the config you should talk to you ISP.
