ip cloud multiple wan selection
i had installed an rb951 with 1 pppoe dsl line (modem bridge mode) and ip cloud was working flawless until yesterday that i add one more dsl line (no bridge mode) for load balancing (pcc) so now ip cloud updates itself with 2 dsl line and i cannot connect remote now.
why there is no option in ip cloud to choose which interface updates from?
is there any way to force to update from pppoe-out1 ?
You should care what connection arrived by which interface and take care to send it’s packets out by the same interface first. Then take care about the ip cloud that doesn’t support multiwan anyway. Use special routing rules for ip cloud to force it going thru one predefined wan interface.
