/ipv6 address print
Flags: X - disabled, I - invalid, D - dynamic, G - global, L - link-local
# ADDRESS FROM-POOL INTERFACE ADVERTISE
0 G 2804:431:c7f2:df3f::/64 pool-ipv6 bridge yes
The IPv4 address is correct.
I tried forcing update, having a 1 min as DDNS update interval and nothing made the IPv6 address show correctly.
How should I get this resolved?
That somehow depends on ISP. In my case, router requests only prefix (but has add-default-route=yes set), stores received prefix into pool (ISP is giving out /56 prefixes). Then it assigns IPv6 address from pool to LAN interface. At this moment it’s got 3 IPv6 interfaces, only one is routable:
> /ipv6 address print
0 G 2a01:xx:yy:zz::1/64 pool-ipv6 bridge yes
1 DL fe80::6c3b:6bff:fe97:256f/64 bridge no
2 DL fe80::6e3b:6bff:fe97:256f/64 ether1 no
And yet IP cloud has both IPv6 and IPv4 addresses:
$ host <serial>.sn.mynetname.net
<serial>.sn.mynetname.net has address 89.xxx.yyy.zzz
<serial>.sn.mynetname.net has IPv6 address 2a01:xx:yy:zz::1
Seems like OP has it more or less exactly the same. Which makes me think there might be some intermittent problem with his router updating IP cloud DNS.
In case it matters: my router is running ROS 6.48.3
