ip cloud without default route
Hi
when my pppoe-out’s “add default route” in activated, ip/cloud works perfect
but
when “add default route” is deactivated it says: “error: no internet connection”
i tried to fix it by (mangle and nat and ip/routes) with udp/15252
any idea please?
How do you expect router will reach cloud server without routes?
Hi mrz
i expect router reach to cloud server without default route
i want to uncheck “add to default route” and use static routes and NAT and Etc…
It is not possible, please read some basic info how routing works.
If you do not need default route then add static route to cloud servers address manually.
If you are unticking “add-default-route” then you simply need to correctly create a route for the router to reach the web.
Can you do an export of your static routes.
