Ip Config
This is what i’m trying to do ..
I have a 64...*/30 ( Internet ) ether1
192.168.0.1.24 ( Nat) (Lan) ether2
64...*/28 ( Public ips ) (Static ips) ether3
Nat is working fine . Lan is working Great . But Can’t get static ips to work could someone Shed some light on this for me . I have tried everthing I can think of .
Is that 3rd subnet routed to you via your first one? If not you can’t use it like that short of using a proxy-arp setup that is an ugly hack and you’ll want to contact your ISP before turning it on to make sure it won’t cause them problems.
I have a ..240.102/30 ( Internet ) ether1
..241.16/28 ( Public ips ) (Static ips) ether3
Its routed via the first one
This is the setup I’m trying to complete .
Public ips need to get from Wan to Ether3 with out Any block or Nat
Post your nat rules and routing table, that is, the output of
/ip firewall nat export
/ip route export
add action=src-nat chain=srcnat disabled=no src-address=192.168.0.0/24 to-addresses=..241.21
[admin@MikroTik] > /ip route export
aug/16/2011 13:16:50 by RouterOS 5.6
software id = YXKP-BFNE
add check-gateway=arp disabled=no distance=1 dst-address=0.0.0.0/0 gateway=..240.101 scope=30 target-scope=10
IP addresses 192.168.0.0/24 and ..241.21 are not in your network diagram. Please post the output of
/ip address print
With a /28 network, .16 is the network address and not a valid IP. The valid range of IP’s is .17-.30.
[admin@MikroTik] > /ip address print
ADDRESS NETWORK INTERFACE
0 ..240.102/30 ..240.100 Wan
1 192.168.0.1/24 192.168.0.0 Lan
2 ..241.16/28 ..241.16 Static
The ip address ..241.16/28 is network address for the /28 subnet, so, you cannot assign it to an interface. Change that address to ..241.21/28 since you are already scr-natting your private IPs to it.
Assign public IPs from ..241.17 - ..241.20 and ..241.22 - ..241.30 to clients connected to ether3. Set their subnet mask to /28 and gateway to ..241.21
This should resolve your issue.
