So i have a RB4011 w/ WiFi and a hAP ac2 setup in cAPsMan, left a backdoor open on a port of the hAP, when I directly connect to it via wire it gives me a address from original config 192.168.88.2, but that is not the address of either of my networks. My laptop says unidentified network and no internet, but still browses the web, I cant see my laptop on any registration from the cAPsMAN or in any dhcp server, it still works, just is invisable. Should this be a concern?
Depends on what you definition of concern is.
There is a DHCP server in your network that is supplying IP addresses.
What do you see when you browse to the corresponding gateway address?
Can you share your config, so we might be able to explain this behaviour?
/export file=anynameyoulike
Make sure to remove serial and any personal info like public IP.
So like, /export compact hide-sensitive file=*?
It responds just like my guest network and is unable to connect, I can connect to management via winbox though.
Thanks for the look
MTB-Debug.rsc (20.2 KB)
Also i would like to setup ping reset on my cap if you could give a lil guidance
So i stand corrected, i apologize i was also connected via WiFi. so via cable off the cAP i cant reach web pages, and I cant reach management via winbox to my main network by IP address, but i can via layer 2.
