ip conflict
Hi Guys need help here..
I have mikrotik ccr1016 and i have a 4 dsl modem, now the 2 modem are static and 2 are dynamic they broadcast diferent ip’s.
the 3 modem i put at at mikrotic port 1/2/3 bond xor and route static to port 5 network bit 26(192.168.13.1/26) but when i put on the network together on a switch hub i cannot get my dhcp modem but when i removed the mikrotik on the switch i can get dhcp on my modem why?
comments and suggestion much appreciated many thanks.
Hello all. after days or week i think looking for answer on my problem and reading on the wiki’s, trial and error i found that called ARP, on my interface in port 5 where i specify an IP as my GW to the network it was set on arp-proxy, i try switch it as enabled and test on the network and never encounter IP CONFLICT for reason and i don’t understand very will it solved my problem.
on my network i can use 1 modem with dhcp and 1 mikrotik that is bonded to my 3 dsl source as my load balance and failover i put together on 1 network as of now i haven’t encounter ip conflict and i can get dhcp Easily if i switch source.
can some1 assist me the logic or ARP i dont really get the explanation on wiki’s. many thanks in advance.
