bes
March 15, 2006, 8:08pm
1
Hi,not work dns static
[admin@juri] ip dns> pri
primary-dns: 212.59.0.1
secondary-dns: 195.14.170.14
allow-remote-requests: yes
cache-size: 10240KiB
cache-max-ttl: 1w
cache-used: 20KiB
And
[admin@juri] ip dns static> pri
Flags: D - dynamic
NAME ADDRESS TTL
0 > http://www.takas.lt > 192.168.3.2 1d
Opening http://www.takas.lt and not works forward to 192.168.3.2
you have to be sure, that router client uses Router DNS as primary dns server configuration,
Redirect NAT rules might be added to forward DNS requests from clients directly to the router, than router DNS cache will be used despite of client PC configuration .
mag
March 16, 2006, 6:18pm
3
i am trying to use this, but to no success. maybe someone could correct me.
using this rule:
add chain=dstnat in-interface=lan dst-port=53 action=redirect to-ports=53
gets
0 ;;; redirect DNS-requests
dig gives me, for example:
dig @192.168.255.3 www.microsoft.de
; <<>> DiG 9.2.2 <<>> @192.168.255.3 www.microsoft.de
;; global options: printcmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 43368
;; flags: qr rd ra; QUERY: 1, ANSWER: 3, AUTHORITY: 0, ADDITIONAL: 0
;; QUESTION SECTION:
;www.microsoft.de. IN A
;; ANSWER SECTION:
www.microsoft.de. 1428 IN CNAME microsoft.de.
microsoft.de. 1428 IN A 207.46.130.108
microsoft.de. 1428 IN A 207.46.250.119
which is ok, but in a web-browser i can’t open any page on the internet.
Protocols have to be specified for NAT rules too, protocol=tcp and second for protocol=udp.
mag
March 17, 2006, 7:24am
5
thx. this one makes it:
add chain=dstnat in-interface=lan protocol=tcp dst-port=53 action=redirect to-ports=53
add chain=dstnat in-interface=lan protocol=udp dst-port=53 action=redirect to-ports=53
