I’m working on a larger script for new inbound load balancing support on Mikrotik and have a question for the script guru’s.
Can I determine (boolean) if a specific IP is within a specific subnet, ie:
:put (10.10.10.5 & 10.0.0.0/8)
This is from the manual - :put (10.16.0.134 & ~255.255.255.0)
I know the & isn’t correct above, I’m just not sure how to accomplish it. I am not sure that the scripting engine even deals with 0.0.0.0/0 style ip addresses at all actually. If I try this:
:put [:toip 10.10.10.1/32]
nothing is output. If I use the above without the /32 it works. I am assuming its not possible but want to throw this one out to the guru’s to show me otherwise.
The main goal is to get a true or false if a specific ip is within a specific subnet. I am making an ‘exclude’ variable that stores ips that should be not matched, ie 10/8, 172.16.x.x, 192.168/16, and any others someone wants to exclude.
The logic is that if you take the subnet mask of the route and AND it with the IP in question. If the IP in question is within that subnet then the subnet address would be equal.
A function such as :put [ / ip route lookup 192.168.1.1 ] would be more convenient )
None of the snippets have been tested before posting. I’m lazy.
I tried a few different combinations of tests but never got my end result right. I would like to use address-list functions but they are way slow (at least from the console :find command they are). Sten, you got me closer… If anyone wants to take a stab at it and get $50 USD I will pay you immediately with paypal. : )
Here is what I am trying to do …
:set bypass “192.168.2.0/24,10.10.50.0/24,172.16.87.64/26”
:set ip 192.168.2.58/32
:if ($ip WITHIN $bypass) do={ } else={ }
I will use ‘: toarray’ and ‘foreach’ the bypass entries to test each one. Basically I need to check if a specific IP address/subnet is within another list of bypass ip addresses/subnets.
Also, whatever block of code it ends up being I need to include in the new inbound load balancing script - if you wish I will mention your code in the comments section. This will be used to exclude certain addresses from any ddns updates that are sent.
“Console has crashed or maybe system is completely busy; please log in again.”
I get the above error - however I think the code is right. I will tweak it and see what I can do to make it work. Is that email below a good paypal addy so i can send you some money?
I wish the scripting engine had some debugging or error logging in it. If one single thing is wrong the script either doesn’t run at all, or just stops running and doesn’t tell you anything. I am always putting :log info “” commands on every other line just to see where things stop, but thats a pain really.
