ip firewall nat problem
Hello, when I set the port mapping according to the official manual, it has no effect. How to troubleshoot the problem? The following is the configuration content。
[admin@MikroTik] /ip firewall nat> print
0 ;;; NAT
chain=srcnat action=masquerade out-interface=pppoe-out1 log=no
log-prefix=“”
1 ;;; NAT
chain=srcnat action=masquerade out-interface=pppoe-out2 log=no
log-prefix=“”
2 ;;; 3389
chain=dstnat action=dst-nat to-addresses=192.168.88.226 to-ports=3389
protocol=tcp in-interface=pppoe-out1 port=3389 log=no log-prefix=“”
The default configuration, the two wan ports have not yet set PCC
Firewall has no other rules set
The client firewall is also down
For port forwarding you have to use the dstnat chain (and not the srcnat chain).
Update: oops…you did that already. Can you share your complete firewall:
/ip firewall export
[admin@MikroTik] /ip firewall> export
oct/30/2022 15:26:56 by RouterOS 6.47.9
software id = TI09-7WK3
add action=masquerade chain=srcnat comment=“\C1\AA\CD\A8NAT\B3\F6\BF\DA”
add action=masquerade chain=srcnat comment=“\B5\E7\D0\C5NAT\B3\F6\BF\DA”
add action=dst-nat chain=dstnat comment=“3389\B6\CB\BF\DA\D3\B3\C9\E4”
in-interface=pppoe-out1 port=3389 protocol=tcp to-addresses=192.168.88.226
to-ports=0
This is all the rules of the firewall, please read it, please. Thank you
Where are the default firewall rules? If this router is connected to the Internet and has a public IP address…you might be in bigger problems than a non-working port forward.
May I advise you to netinstall this device and keep the default firewall rules. From there, you can start with adding additional rules (like adding the pppoe interfaces to the WAN addresslist.
[admin@MikroTik] /ip firewall> filter print
Hello, at present this router has two public ip addresses, the current configuration is only two PPPOE, the current configuration is only DHCP, NAT, DNS, other configurations have not been added, they are all factory defaults, is it a bug?
At least the default configuration is not complete. You might want to consider adding the default firewall rules (but it might cause a non working router).
Perhaps better to share the complete config befor making any changes:
/export hide-sensitive file=anynameyoulike (remove any private information and place it in between code tags).
What device is it?
What RouterOS version is it running?
https://forum.mikrotik.com/viewtopic.php?t=180838
Ok thanks, I’m trying to reinstall a new version.
