IP Firewall NAT rules for ISP CPE DMZ scenario
I have network diagram as below.
I can access web server from WAN, but not from LAN.
I need similar solution as explained here https://wiki.mikrotik.com/wiki/Hairpin_NAT , however my network diagram is different and I need different solution.
So far my configuration is very basic:
[user@mikrotik] > ip address print
 #   ADDRESS            NETWORK         INTERFACE
 0   ;;; WAN
     192.168.8.254/24   192.168.8.0     ether1
 1   ;;; LAN
     192.168.0.254/24   192.168.0.0     bridge
[user@mikrotik] >
[user@mikrotik] > ip firewall nat print
 0    ;;; defconf: masquerade
      chain=srcnat action=masquerade out-interface-list=WAN ipsec-policy=out,none
 1    ;;; HTTP port forwarding to 192.168.0.1
      chain=dstnat action=dst-nat to-addresses=192.168.0.1 to-ports=80 protocol=tcp dst-address=192.168.8.254 dst-port=80 log=no log-prefix=""
[user@mikrotik] >
[user@mikrotik] > ip route print
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme, B - blackhole, U - unreachable, P - prohibit
 0 A S  ;;; default route
        0.0.0.0/0                          192.168.8.1               1
 1 ADC  192.168.0.0/24     192.168.0.254   bridge                    0
 2 ADC  192.168.8.0/24     192.168.8.254   ether1                    0
[user@mikrotik] >
Could you suggest missing NAT rules, so that web server could be accessible from LAN?
