Can I configure IP-Helper in Mikrotik…if yes how can i do it…
Regards
Rakesh
Regards
Rakesh
IP - Firewall - Service Ports
There is no option regarding IP-Helper in IP-Firewall-Service Ports as mentioned by you…can you confirm whether IP-Helper configuration is possible in Mikrotik or not?
Regards
Rakesh
you cannot make your own, only whats built into the serivce ports list. there is an ftp helper, pptp helper, and some others. cisco calls them ip helpers, mikrotik calls them service ports. what is the goal and maybe there is a different way to accomplish it.
I want to configure IP-Helper on one of the Interfaces of a Mikrotik to re-direct the broadcasts received on that interface to a dhcp-server hosted on a different network.
Please see the attached network diagram of the scenario…I have an IP-Sec Tunnel running in between cisco router and Mikrotik.
The same scenario works vice-versa when the host the DHCP server on the LAN side of Mikrotik and the clients on the LAN side of the Cisco Router,enabling IP-Helper on the LAN interface of the cisco router.
Please suggest…
Regards
Rakesh
see dhcp-relay…
