Ip-Helper
How to configure IP-Helper address in mikrotik.
Srinivas
What ip helper you are talking about?
Ip helper adress is used in cisco ios for dhcp relay.
So if i’m right you’ll have to look at IP DHCP-Relay.
regards
(edited: typo)
In Cisco you have an ip helper-address command which can be used to forward UDP broadcasts as unicast to an off subnet host. This command is commonly used to forward DHCP requests to a centralized DHCP server, but can be used for other purposes.
If you’re looking to forward DHCP you can use /ip dhcp-relay. Assuming your subnet is 192.0.2.0/24 you would use:
/ip dhcp-relay
add name=dhcp-relay interface=ether1 dhcp-server=<server_address> local-address=192.0.2.1
I’m not sure how you could forward other protocols if you’re looking to do that.
