/ system script add name=“test” source={
/ip hotspot user print
/ip hotspot user set 0 password=pink
when I run the test script it does not change the password, what have I got wrong in the script?
thanks
thanks
You can’t user item numbers in scripts - this has been covered numerous times here in the forum. To reference an entry in a script you have to use the “find” command in your script - search the forum and/or manual for lots of examples.
Best regards,
Christian Meis
thanks
Just found this thread while trying to do the very same thing - so in the interest of more complete research facilities:
On 2.9.20, if your user is ‘user1’, then the script line is:
/ip hotspot user set user1 password=pink
B)
