Well, I won’t lie, this part of RouterOS is something where I’m sure that I still have a lot to learn.
But AFAIK PCC is just a matcher for connections, I don’t see any indication anywhere that it should care about anything else.
Regarding recursive routes, I already admitted to them being new to me, so there might be some problems I’m not aware of. But in this specific case, I don’t see any reason why it wouldn’t work. I actually did test it. Not exactly with real two ISPs, only in simplified minilab, but if nothing else, it at least isn’t completely broken. ![]()
Recursive routes is not the only way. If you keep netwatch, then with four routes like this:
add distance=1 gateway=10.111.0.2 routing-mark=to_ISP1 comment=PROVIDER1
add distance=10 gateway=10.112.0.2 routing-mark=to_ISP1
add distance=1 gateway=10.112.0.2 routing-mark=to_ISP2 comment=PROVIDER2
add distance=10 gateway=10.111.0.2 routing-mark=to_ISP2
raising distance of first one in each table above 10 would make the other one (backup) active.
References to any materials proving that I may be wrong are welcome. Not that it would make me exactly happy, but better than keep being wrong in future. ![]()
