Does anybody know if it is possible to read the /ip neighbour information via SNMP?
I am trying to make a network map, and it would be nice to have this option.
No, there is no SNMP information provided from ‘ip neighbor’, but you can use Dude to build a network a map, additionaly you will have a lot features for network administration using Dude,
http://www.mikrotik.com/thedude.php
You can look at the Dude forum or check the wiki for the Dude configuration.
I understand that The Dude can be used for this.
But we are currently using another program(HP OpenView) for the network, and it would be nice to use SNMP for this. But if it isn’t implemented, then we must find another way to make the map.
RouterOS supported OIDs are listed here,
http://www.mikrotik.com/testdocs/ros/2.9/root/snmp_content.php#2.5.4
