Hi All,
I want to know if it is possible to create a full class A, B or C in the private range in ip pool.
I check the manual, it is not clear if we can do it if it is availabe as a feature.
/ip pool> add ranges=
Ranges ::= Range[,Ranges] (max 100 times)
Range ::= A.B.C.D[-A.B.C.D |0..32 |/A.B.C.D ] (IP address range)
[zaherhamiyah@test] /ip pool> add ranges=192.168.0.1/16-192.168.10.254/16
value of range must have ip address before ‘-’
So, is it:
1- add ranges=192.168.0.1/16-192.168.10.254/16 (gave error as above)
2- add ranges=192.168.0.0/16 (not sure if it will work)
3- add ranges=192.168.0.1-192.168.0.254,192.168.1.0-192.168.1.254 (again not sure about this one also)
Any Ideas?
Thanks.
