Only one firewall filter: to block icmp
I can use web proxy to access same host and port on same ethernet ports.
Besides dst-nat for forwarding, only NATting done is outbound masquerade.
I’m testing w/ web browser; place ip_address:port number in address bar.
Whenever I try to access the host, I see the bytes and packets counters increase.
If you see the counters going up, that means the rule is working and doing what it is supposed to. Run torch on your LAN interface to see the traffic going to the server you are forwarding to and see if it is replying back. Are you doing anything with load balancing or policy based routing?
Post the output of “/ip address print detail”, “/ip route print detail”, “/interface print”, “/ip firewall export”, and an accurate network diagram.
Also ensure that the host firewall on the server is accepting traffic. Windows 2008/R2, 7 and Vista all have the concept of different areas, where a firewall can be configured to only let traffic in when it’s sourced from the same subnet, etc. Run a packet sniffer on the Dude server to see if the packets make it there.
