Ip-proxy long header error 400 (hotmail)
I’ve been debugging a problem with a user that couldn’t log into hotmail when using ip-proxy, it receives a 400 http proxy error.
With help of firefox’s http-live-headers i could reproduce it on several places, and tested mikrotik versions 2.9.9, 2.9.19 and 2.9.43.
The request is about 4200 bytes long, if i cut at little less than 4096 then it works. I know it’s huge, but it’s happening for real.
This is the request (sorry for ultra long lines). I replaced some characters by “.” for security reasons:
http://by133w.bay133.mail.live.com/mail/TodayLight.aspx?n=1368606487
GET /mail/TodayLight.aspx?n=1368606487 HTTP/1.1
Host: by133w.bay133.mail.live.com
User-Agent: Mozilla/5.0 (Windows; U; Windows NT 5.1; es-ES; rv:1.8.1.3) Gecko/20070309 Firefox/2.0.0.4
Accept: text/xml,application/xml,application/xhtml+xml,text/html;q=0.9,text/plain;q=0.8,image/png,*/*;q=0.5
Accept-Language: es-es,es;q=0.8,en-us;q=0.5,en;q=0.3
Accept-Encoding: gzip,deflate
Accept-Charset: ISO-8859-1,utf-8;q=0.7,*;q=0.7
Keep-Alive: 300
Connection: keep-alive
Cookie: MUID=..............................4D; ANON=A=..............................FF&E=5ca&W=1; NAP=V=1.5&E=570&C=....................RX__..............................&W=1; ..........=; ..........=; PPLState=1; RPSTAuth=............................................................BYYLLLI+pw/..............................txWZV+..................................................lX8E+....................AyFSI/7m+..................................................8Zzk/..............................qjjljIVW+......................................................................hz4zjpT+..........Ttxx/3VnY4z/....................+..........OFq/H7eJndDS4/............................................................................................................../..........achXRpFC/iRrrF/............................../........................................FBP9GL+V/....................Ehz1+s8gkuvS/..........LWNAQ==; MSPAuth=......................................................................AI7wzjT7*JIC*..................................................pOO5fwII$; MSPProf=....................eaN!....................oAExxMPP!..........!..........................................................................................qYi!..........kqnZ!..........xba*........................................Sln4d!B9Rca*..............................Mca*..........vP1!..........................................................................................UiWwwpUck; MSNPPAuth=............................................................iBMNpAQfy*..........9!..............................m!........................................6N6FlGPbE*3!........................................e4O6GSxZl*..................................................................................................................................*............................................................g4nYZu!..........M*............................................................yjH5D7!..............................5!........................................KPFDj*....................HyVQm!..........IDnFDDSSx*..........2psH!..........AoRvH4y*....................ivNZg3!....................4NxyV!*............................................................; UIC=..........jiy6e4Q!............................................................*....................T6lf3!......................................................................ORSmsUZD!..................................................YRubWl!......................................................................Q$$; mt=........................................|..........4b70b1; KVC=11.10.0000.0115; KSC=....................!........................................5*W!!eLZEDW!..........GVH4xZq*........................................04ikC!..................................................2Purb3!........................................nYfgMxg3q!......................................................................l90Qo*..........................................................................................7R07D9oCl!..........*i!........................................dbg8cu!....................odC1i6P*EB4qD!*..............................qptQfHh7!......................................................................NgW*cO4I!....................G*..........K3SDf4ihd!P5PCcN*....................YhcbJPI7o*..............................BAv5ueWZj*S9U6CwM!................................................................................................................................................................dl9h!kqg6W!....................................................................................................G6MxRLZ*....................o!..........fSX4f*..........22C
Cache-Control: max-age=0
And this is the response:
HTTP/1.x 400 Bad Request
Content-Length: 103
Connection: close
Web-proxy seems not to suffer from this problem. Maybe ip-proxy needs to raise max http request lenght value ?
I’ve used default configuration for ‘ip proxy’ (2.9.44 version, web-proxy test enabled), I have not been able to reproduce any issues with login to HotMail. Could you provide your proxy configuration ? Is it posssible to login to HotMail without proxy enabled ?
Actually the problem does not always happen, i’ve verified with IE6 and FF2. Sometimes happens at login, and other times it allows to login but then fails at loging out.
The big cookie is only sent when loging to that account (no matter what computer or browser using). Other accounts generate a reasonable sized cookie.
Yes. Using only web-proxy work too, either by configuring browser to do it or redirecting in firewall to port 3128.
If you are an admin I can give you the account data so you can reproduce the problem.
Try and change http 1.1 settins in IE. ( Tools > Internet options > Advance ) .
Try with both settings enabled or both disabled.
