How long should a drive format take for the proxy?
and will it give any notification in the logs?
Running 2 sata drives, 1 is a smaller drive running MT, the 2nd one I want to format and use as the cache.
Whenever I try to set it as the cache drive at the moment it doesn’t error but goes back to using the system drive.
Or if I then try rebooting, and try to set it, I’m told to format the second drive first.
