Ip public
Hi
Just one question.
I have FAI with routeur board is bridge.
I never configure mikrotik with a router board un bridge mode .
I have an puplic ip ,How to configure mikrotik to have internets accès.
Br
What means FAI?
If the modem/router device provided by the ISP is in bridge mode, you need to configure a DHCP client or PPPoE client on the WAN interface of your Mikrotik, and you may need to attach one of these to the WAN interface via a VLAN interface. Which setup you need in particular depends on the ISP - some use VLAN tagging for the internet service, some don’t, and the same applies for the choice between PPPoE mode and DHCP client mode. For PPPoE, you may also need to know a username and a password.
