I have two interfaces (ADSL) with dynamic IP and gateway. In order to have a failover mechanism between these two interfaces I want setup a check-gateway failover as described in: http://wiki.mikrotik.com/wiki/Two_gateways_failover
As my two gateways are dynamic I need to change the gateway IPs dynamicly. The Idea now was to write a script which periodicly checks the ADSL GW and configures the route.
My problem now is, that I have a route with a routing-mark=RED_DEFAULT but I can not find the route using “ip route find routing-mark=RED_DEFAULT”. A find for the interface works well.
Example:
[admin@svgateway] /ip route> print detail
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme,
0 S dst-address=0.0.0.0/0 gateway=192.168.11.1 interface="" check-gateway=ping gateway-state=unreachable distance=1
scope=30 target-scope=10 routing-mark=RED_DEFAULT
1 ADS dst-address=0.0.0.0/0 gateway=213.191.64.54 interface=RED_Default gateway-state=reachable distance=1 scope=30
target-scope=10
2 S dst-address=0.0.0.0/0 gateway=192.168.11.2 interface="" gateway-state=unreachable distance=2 scope=30 target-scope=10
routing-mark=RED-BACKUP
3 ADC dst-address=84.58.0.1/32 pref-src=84.58.50.211 interface=RED_Backup distance=0 scope=10
4 ADC dst-address=192.168.150.0/24 pref-src=192.168.150.1 interface=BLUE_wlan1 distance=0 scope=200
5 ADC dst-address=192.168.151.0/24 pref-src=192.168.151.1 interface=BLUE_svhotspot distance=0 scope=200
6 ADC dst-address=192.168.168.0/24 pref-src=192.168.168.1 interface=GREEN_ether3 distance=0 scope=10
7 ADC dst-address=213.191.64.51/32 pref-src=92.226.211.101 interface=RED_Default distance=0 scope=10
[admin@svgateway] /ip route> :put [find routing-mark=RED_DEFAULT]
[admin@svgateway] /ip route> :put [find interface=RED_Backup]
*42037ca7
Any suggestions? Is this a bug? Is there a better way to do this?
Cheers
Pug
