Hi
How to do an equivalent
ip r g 1.1.1.1
on mikrotik ? On linux it gives route that matches given ip address. Consider following example. You have 2 routers connected to each other with ether1. On R2 you have 1.1.1.1/30 on ether2. You are logged on R1 and want to know what is the route for 1.1.1.1 Trace route will not show you the nexthop address. It will only show you 1.1.1.1
