Mark Routing & IP Route in RouterOS V6 it’s simple and better than RouterOS V7
Please return it like it was in the previous version, it is simpler and easier
Now it is complicated and difficult
Please, can you explain more?
I enter the command:
"/ ip firewall mangle
add action = mark-routing chain = prerouting connection-mark = from-ISP1 new-routing-mark = to-ISP1 passthrough = yes "
in response I get:
“input does not match any value of new-routing-mark”.
How to do it correctly?
Now you have to add new routing table “from-ISP1”. The routing table is no longer added dynamically as in RouterOS 6.
this not available in RouterOS v7
It’s still there, only you have to create routing table in /routing/table/, it doesn’t happen automatically as in v6.
Can u share and give the example in v6 and v7.
Here is explained the difference between v6 and v7 with the example:
https://help.mikrotik.com/docs/display/ROS/ROSv7+Basic+Routing+Examples#heading-UseofRoutingTablesandPolicyRouting
