IP Route not working
I have a topology:
and my ip route configuration:
ping result:
can you help me, please? what do I miss in my configuration? thank in advance.
Please post
/ip address export
/ip firewall nat export
Please check your cisco will actually reply to an ICMP Ping ?
Also check if the interface the IP address 22.22.22.1/24 is attached to is active. If not then the IP may also not be active.
What about pinging 22.22.22.2 ? does this work ? What about traceroute ?
The cisco is physically attached to both subnets so routing should be ok. Does the PC have 22.22.22.1 as it’s default gateway ?
The rule is you need a route to the host and the host needs a route back :slight_smile: (and no firewall’s stopping your tests)
