IP ROUTE ROS7 between ROS6 problem
Hello everyone,
I need help with configuration ip route on ROS 7 between ROS6 (ikev2 tunnel)
When i update one router to version 7.8 i have a problem with ping second location.
On 1 router (ROS6) i have configuration only:
/ip route> print
DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 A S 0.0.0.0/0 xx.xx.xx.xx 1
1 ADC xx.xx.xx.xx/30 xx.xx.xx.xx WAN 0
2 A S 192.168.0.0/24 bridge1 1
3 ADC 192.168.1.0/24 192.168.1.1 bridge1 0
On second router (ROS7) i have the same configuration but when i add route ping doesn’t work, when i delete route ping ok but i don’t have communityto other side.
Flags: D - DYNAMIC; X, I, A - ACTIVE; c, s, y - COPY
Columns: DST-ADDRESS, GATEWAY, DISTANCE
DST-ADDRESS GATEWAY DISTANCE
0 As 0.0.0.0/0 xx.xx.xx.xx 1
DAc xx.xx.xx.xx/30 WAN 0
1 As 192.168.0.0/24 bridge1 2
DAc 192.168.1.0/24 bridge1 0
Can you help me what i need to make on ROS7?
The topic title is wrong
I changed it, i hope now is ok.
Setting the interface as a gateway over broadcast networks is an invalid setup.
Could you talk me what is wrong? Maybe can you show me example config?
When i use two software ROS6 i don’t have this problem.
I already mentioned what is wrong, you cannot use interfaces as gateways on broadcast networks, set IP address instead of an interface. Such setups didn’t work reliably on any version including v6.
What gateway i must use ?
  • public ip other side ?
  • local /24 v6?
  • local /24 v7?
    v6 Router :
    IP LOCAL: 192.168.0.0/24
v7 Router:
IP LOCAL: 192.168.1.0/24
@mrz
Can u send example configuration for this ?
I use IPSEC IKEV2 and only IP ROUTE to connect to different location.
This is very important for me.
Unfortunately, I cannot guess the IP addresses, the gateway should be the IP address of the host behind which the network is located.
What do i need when i have 3 location ipsec on one router?
Need I to change Scope and Scope Target for this ?
