ip/route > rules
I created three rules in the Rules tab, adding a table to each network.
10.10.1.0 action=lookup table 200
10.10.2.0 action=lookup table 300
10.10.3.0 action=lookup table 400
So I created three routes defaults for each table created above.
address1 with table 200
address2 with table 300
address3 with table 400
ie, the network has a default route 10.10.1.0 the address1
10.10.2.0 is the network as the default route address2
and the network has a default route 10.10.3.0 address3
The question is, how it will deal with MikroTik?
if I go in the “new terminal” ping 10.10.3.10 ee, and as the source address 10.10.2.1 (let’s say I put in an address interface MikroTik), how will the referral process?
The process that MikroTik will adopt is to send the default route 10.10.2.0, or be a directly connected route (the 10.10.3.0) will ship directly through the interface that has the 10.10.3.1 address?
Att,
Victor
Hello
when you create a separate routing table for source address then main routing table will be ignored for that source address in rules.
So if I ping 10.10.1.x having a source address 10.10.2.x,
the process adopted by MikroTik will send to the default route 10.10.2.x, not
10.10.1.x send directly through the interface, as a directly connected route?
Yes that’s right.
