Hi Fewi,
Thanks for your reply, here is the information you wanted:
Also by taking a blunt approach like that wouldn’t the connection go down every minute whilst the rules update?
Bridge has all ethernet ports 2-5 attached to it.
Ethernet 1 is the WAN port
Before VPN connection:
/ip dhcp-client
add add-default-route=yes comment="default configuration" \
default-route-distance=5 disabled=no interface=ether1-gateway use-peer-dns=\
yes use-peer-ntp=yes
/interface print detail
0 R name="ether1-gateway" type="ether" mtu=1500 l2mtu=1524
1 R name="ether2-local-master" type="ether" mtu=1500 l2mtu=1524
2 name="ether3-local-slave" type="ether" mtu=1500 l2mtu=1524
3 R name="ether4-local-slave" type="ether" mtu=1500 l2mtu=1524
4 name="ether5-local-slave" type="ether" mtu=1500 l2mtu=1524
5 X name="PPTPgates.com" type="pptp-out"
6 X name="sstp-vpn" type="sstp-out"
7 X name="vpn-l2tp -L2TP" type="l2tp-out"
8 R name="bridge1" type="bridge" mtu=1500 l2mtu=1524
/ip address print detail
0 ;;; default configuration
address=192.168.88.1/24 network=192.168.88.0 broadcast=192.168.88.255
interface=bridge1 actual-interface=bridge1
1 D address=91.74.11.139/24 network=91.74.11.0 broadcast=91.74.11.255
interface=ether1-gateway actual-interface=ether1-gateway
/ip route print detail
0 ADS dst-address=0.0.0.0/0 gateway=91.74.11.1
gateway-status=91.74.11.1 reachable ether1-gateway distance=5 scope=30
target-scope=10 vrf-interface=ether1-gateway
1 A S ;;; route for PPTPgates
dst-address=89.149.227.157/32 gateway=91.74.11.1
gateway-status=91.74.11.1 reachable ether1-gateway distance=1 scope=30
target-scope=10
2 ADC dst-address=91.74.11.0/24 pref-src=91.74.11.139 gateway=ether1-gateway
gateway-status=ether1-gateway reachable distance=0 scope=10
3 ADC dst-address=192.168.88.0/24 pref-src=192.168.88.1 gateway=bridge1
gateway-status=bridge1 reachable distance=0 scope=10
VPN Connected:
/ip dhcp-client
default-route-distance=5 disabled=no interface=ether1-gateway \
use-peer-dns=yes use-peer-ntp=yes
5 R name="PPTPgates.com" type="pptp-out" mtu=1380
7 X name="vpnl2tp -L2TP" type="l2tp-out"
/ ip address print detail
2 D address=192.168.177.3/32 network=192.168.177.1 broadcast=0.0.0.0
interface=PPTPgates.com actual-interface=PPTPgates.com
/ ip route print detail
0 ADS dst-address=0.0.0.0/0 gateway=192.168.177.1
gateway-status=192.168.177.1 reachable PPTPgates.com distance=1
scope=30 target-scope=10
1 DS dst-address=0.0.0.0/0 gateway=91.74.11.1
scope=30 target-scope=10 vrf-interface=ether1-gateway
2 A S ;;; route for vpngates PPTP
3 ADC dst-address=91.74.11.0/24 pref-src=91.74.11.139 gateway=ether1-gateway
4 ADC dst-address=192.168.88.0/24 pref-src=192.168.88.1 gateway=bridge1
5 ADC dst-address=192.168.177.1/32 pref-src=192.168.177.3
gateway=PPTPgates.com gateway-status=PPTPgates.com reachable
distance=0 scope=10
