I built a Wireguard VPN between two routers.
The handshake is already exchanged.
But…
How do I get it to only route a specific IP address into the VPN tunnel?
I have already looked at a few instructions, but they all don’t really work.
My goal is to route the one specific IP address from the other location through my public IP.
If anyone has a solution I would be very grateful!
I would make a mangle rule to route traffic from a specific IP in to the tunnel, i used an l2tp tunnel in my example but i think the same applies for wireguard;
VPC11> trace 1.1.1.1
trace to 1.1.1.1, 8 hops max, press Ctrl+C to stop
1 172.16.0.1 0.421 ms 0.370 ms 0.325 ms
2 192.168.159.2 1.018 ms 0.618 ms 0.651 ms
3 * * *
VPC12> trace 1.1.1.1
1 172.16.0.1 0.716 ms 0.302 ms 0.338 ms
2 192.168.2.1 0.978 ms 0.859 ms 0.918 ms
3 192.168.159.2 1.427 ms 1.343 ms 1.246 ms
4 * * *
If you don’t want to NAT traffic in to the tunnel, you have to make sure there is a route back on the other side of the tunnel;
If you dont want the single user EVER to be able to access LOCAL WAN, if the wireguard connection goes down then change action: action=lookup-only-in-table
You may need the single user to be able to reach other users in the same subnet or perhaps another subnet on the router. In this case you will need routing rules before the one just made to ensure desired traffic does not go out the wireguard tunnel.
This will work for both cases,
a. single IP originates traffic to subnet user/device
b. single IP is responding to (return traffic) to a subnet user/device.
Discussion: What we are doing is creating an additional table and then making a route which includes that table.
Via the Routing Rule we identify traffic that should adhere to the routing rule.
Hence any traffic ( ANY TRAFFIC ) leaving the source IP identified will go out the wireguard tunnel. Thus we have to consider all the traffic and deal with it.
This method works well for a whole subnet, or a few users.
Clearly if one has users from various subnets or a huge amount of users from a single subnet, it gets more efficient to mangle.
