ip routes are not working, ros freezes and not response
Hi, sorry for my bad English.
I have 2 licenses Microtik (Level 6) installed on 2 pcs, and on both machines the same thing happens.
Ips routes stop working and the router loses connectivity over IP, I can only access using the MAC.
I have recorded a screencast that you may see exactly what is happening in my router.
http://www.screentoaster.com/watch/stWEtXRENIR19aQ1teXVxQVl9V/mikrotik_router_os_ip_route_problem
Please, I tried 1000 things, I searched on google, this forum and find nothing related
any guru can help me?
looks like the routing program is having a problem. make a supout.rif file and send to support
I can not create the supout.rif file, the router can not export the (ip route) settings correctly and stays “frozen”.
just type “/system sup-out” and wait for a few hours, it will finish eventually
ok, I got it, I will send to technical support.
Thanks for the help
:open_mouth:
You are not alone in this issue. I have been experiencing the same thing. For me, it is triggered by changes made to OSPF on any adjacent routers. It even happens sometimes when the physical interface goes up and down. I am working with MikroTik support on this one.
Tech support guys told me:
Cause of the crash is frequent interface status changes. This bug is fixed in v4.6, wait for next RouterOS release.
I’m waiting impatiently for this update, but it’s good to know they have controlled this bug.
