IP Routes can be disabled using scripting.
when using command line in mikrotik, to disable ip route manually
for ex: i enter
/ip route set disabled=yes 10 (number of route item)
if i add or remove routes the item number gets changed
i want to disable specific routes at specific intervals
so is there any way to disable/enable routes by identifying comment or something similar using scripting.
/ip/route/disable [find comment=“$comment”]
Reply on compatible way, if the user use RouterOS v6, do not provide commands for RouterOS v7 only…
/ip route disable [find where comment~"search this text on the comment"]
