Does any1 have experiece to make Ip Sec between 4-5 ethernets with rb 750 ?
(does it possible?)
I have problem now, cos I change router local IP from 192.168.0.1 to 192.168.1.1,
problem is that I cant open router in browser!!
You think wrong. Change your workstations IP to be in the same subnet as your router is.
when I change IP/Services /WWW on 0.0.0.0/0 my rb750 start working in browser .
I wants to know how can I make same network from 4-5 different locatons with static IP.
They all use XP OS , ADSL 4Mb/128kbs.
I make IP sec between 2 ethernets(rb750 on evry side), but I dunno how many networks can connect with this
IP Sec protokol?
Try to tell us the outcome you wish to achieve
We have main Server on location X.On locations y,z,w we have business centre.Every center need to sent data on main server every day.
Main server use win2003r2 & there is Frame Relay.I wanna make connection from centers to main server non stop without using icons for connect.
Simple!
Mikrotik router in the main office and in each branche! In RouterOS you make IPIP tunnels. Pluses all RouterOS features. Minuses - need to buy Mikrotiks for each branch.
Mikrotik in main office and whocareswhat in branches. PPTP server in main office and VPN client on wrkstns in branches. Pluses - cheaper (if you allready have some cheap routers in branches). Minuses - must dial in each time, and some I can’t imagine now but do expect.
