Ip-sec problem. subnets
Hello. I have setted up a few ip-sec tunnel. When i’m trying to ping every subnet only one pings correctly but others get timeout exception. What’s the point?
config:
# jun/15/2022 09:52:52 by RouterOS 6.49.6
# software id = 2TA3-2AX8
# model = RB3011UiAS
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip ipsec profile
set [ find default=yes ] dh-group=modp1536 enc-algorithm=aes-256 \
    hash-algorithm=sha256 nat-traversal=no
add dh-group=modp1536 enc-algorithm=des name=MPK
add dh-group=modp1536 enc-algorithm=des name=svk-3
add dh-group=modp1536 enc-algorithm=des name=svk-4
add dh-group=modp1536 enc-algorithm=des name=CPK
/ip ipsec peer
add address=93.153.xx.xx/32 local-address=213.189.yy.yy name=SVK-4 \
    profile=svk-4
add address=84.42.1xx.xx/32 local-address=213.189.yy.yy name=MPK profile=MPK
add address=81.3.1xx.2xx/32 local-address=213.189.yy.yy name=SVK-3 profile=\
    svk-3
add address=79.171.xx.xx/32 local-address=213.189.yy.yy name=CPK profile=\
    CPK
/ip ipsec proposal
set [ find default=yes ] disabled=yes enc-algorithms=null pfs-group=none
add enc-algorithms=des lifetime=1d name=MPK pfs-group=modp1536
add enc-algorithms=des lifetime=1d name=svk-3 pfs-group=modp1536
add enc-algorithms=des lifetime=1d name=svk-4 pfs-group=modp1536
add enc-algorithms=des lifetime=1d name=CPK pfs-group=modp1536
add name=dhcp ranges=10.18.10.50-10.18.10.250
add address-pool=dhcp disabled=no interface=bridge name=defconf
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=ether9
add bridge=bridge comment=defconf interface=ether10
add bridge=bridge comment=defconf interface=sfp1
add address=10.18.10.254/24 comment=defconf interface=bridge network=\
    10.18.10.0
add address=213.189.xx.xx/30 interface=ether1 network=213.189.206.xxxx
add address=10.7.202.0/24 disabled=yes interface=bridge network=10.7.202.0
/ip dhcp-client
add address=10.18.10.0/24 comment=defconf gateway=10.18.10.254 netmask=24
set allow-remote-requests=yes servers=10.7.202.21,10.7.202.22
/ip dns static
add address=10.18.10.254 comment=defconf name=router.lan
/ip firewall address-list
add address=10.15.2.0/24 disabled=yes list=bruteforse_stage1
add action=accept chain=input comment=int dst-port=\
    123,161,500,1701,4500,3081,3080 in-interface=ether1 protocol=udp
add action=accept chain=input comment="ipsec policy" protocol=ipsec-esp
add action=accept chain=output protocol=ipsec-esp
add action=accept chain=input comment=new disabled=yes dst-address=\
    84.42.11.38 in-interface=ether1 protocol=ipsec-esp src-address=\
    213.189.206.174
add action=accept chain=input disabled=yes dst-address=84.42.xx  dst-port=\
    500 in-interface=ether1 protocol=udp src-address=213.189.2xx.xx \
    src-port=500
add action=accept chain=input disabled=yes dst-address=213.189.xxxx \
    dst-port=500 in-interface=ether1 protocol=udp src-address=84.42.xxxx \
    src-port=500
add action=accept chain=input disabled=yes dst-address=213.189.xxxxx\
    in-interface=ether1 protocol=ipsec-esp src-address=84.42.1xxxxx
    established,related,untracked
add action=accept chain=input comment=WinBox dst-port=8291 protocol=tcp
add action=add-src-to-address-list address-list=bruteforse_stage1 \
    address-list-timeout=1w3d chain=input comment="bruteforse add to stage2" \
    connection-state=new dst-port=3389 protocol=tcp src-address-list=\
    bruteforse_stage1
add action=drop chain=forward comment="DROP- invalid DDOS" connection-state=\
    invalid
add action=drop chain=input connection-state=invalid
/ip firewall mangle
add action=mark-routing chain=prerouting dst-port=80 new-routing-mark=ORA \
    passthrough=yes protocol=tcp
add action=mark-routing chain=prerouting disabled=yes dst-address=\
    10.15.2.0/24 dst-port=80 new-routing-mark=2 packet-mark="" passthrough=\
    yes protocol=tcp routing-mark=main src-address=10.18.10.0/24
    ipsec-policy=out,none out-interface-list=static
add action=accept chain=dstnat disabled=yes in-interface=ether1 src-address=\
    10.18.10.0/24
/ip ipsec identity
add peer=MPK secret=coral-meat
add peer=SVK-3 secret=coral-meat
add peer=SVK-4 secret=coral-meat
add peer=CPK secret=coral-meat
/ip ipsec policy
set 0 disabled=yes
add comment=MPK dst-address=10.7.202.0/24 peer=MPK proposal=MPK src-address=\
    10.18.10.0/24 tunnel=yes
add comment=SVK-7 dst-address=10.15.2.0/24 peer=MPK proposal=MPK src-address=\
add comment=CPK dst-address=192.168.144.0/24 peer=CPK proposal=CPK \
    src-address=10.18.10.0/24 tunnel=yes
add comment=SVK-3 dst-address=192.168.61.0/24 peer=SVK-3 proposal=svk-3 \
add comment=SVK-1.2 dst-address=192.168.20.0/24 peer=MPK proposal=MPK \
add comment=SVK-8 dst-address=10.16.2.0/24 peer=MPK proposal=MPK src-address=\
add comment=SVK-5 dst-address=10.13.10.0/24 peer=MPK proposal=MPK \
add comment=SVK-6 dst-address=10.14.10.0/24 peer=MPK proposal=MPK \
add comment=SVK-9 dst-address=10.17.10.0/24 peer=MPK proposal=MPK \
add comment=SVK-4 dst-address=10.12.2.0/24 peer=SVK-4 proposal=svk-4 \
add comment=int distance=1 gateway=213.189.xxxxx
add comment=IP-sec distance=1 dst-address=10.7.202.0/24 gateway=bridge
add comment=IP-sec disabled=yes distance=1 dst-address=10.15.2.0/24 gateway=\
    bridge
add comment=int distance=1 dst-address=10.18.10.0/24 gateway=213.189.xxxxx
add comment=IP-sec disabled=yes distance=1 dst-address=192.168.144.0/24 \
    gateway=bridge pref-src=10.18.10.254
/ip route rule
add disabled=yes dst-address=10.15.2.0/24 src-address=10.18.10.0/24 table=2
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/lcd
set time-interval=daily
/system clock
set time-zone-name=Europe/Moscow
/tool mac-server
/tool mac-server mac-winbox
When you want to make an IPsec setup with many subnets and the peers are under your control (e.g. they are branches of your company), I advise you to step back and use a different solution: GRE or IPIP tunnels over IPsec transport, with auto-routing using BGP or OSPF.
Enough can be found on this topic on the forum.
there are only ip-sec settings. before that, there was a fortinet. everything worked there.
Is the other side still a fortinet or is there another MikroTik with the same (mirrored) configuration?
Yes, the other side is Fortinet(MPK). L2 channel on 6 addresses is connected in Fortinet. The correct policy is below
/ip ipsec policy
add comment=MPK dst-address=10.7.202.0/24 peer=MPK proposal=MPK src-address=10.18.10.0/24 tunnel=yes
I am able to see the IPs from other subnets via Torch . But I have no access to them
Probably a NAT problem. You have a NAT avoidance rule but it is disabled and it is below the masquerade rule, should be above.
included, placed above everything. nothing has changed
maybe routes are needed?
routes are not needed as long is there is some route for the traffic. that would normally be the default route that points to internet.
I will leave it to others to answer, I am not a fan of this configuration, I use GRE/IPsec to solve this kind of issues.
Thanks for assistance man
upd
