I made ipsec between cisco and MT. The tunnel establishes fine. However no traffic goes through. If i try to ping from LAN side of MT to LAN side of cisco only the one “current bytes” counter increments. The one with MT public address as src address. If i do tracert to the LAN address behind cisco i get 0.0.0.0 timeout message. I must be missing some firewall/NAT rule, please help?
If you’re masquerading, you need to create a NAT rule before all the other NAT rules with the source network and destination netwokt with Action: accept
This it’s for disable masquerading
