IP SEC
Hello Everyone!!!
I follow the mk example to make a Ipsec VPN http://www.mikrotik.com/documentation/manual_2.7/IP/IPsec.html to make IPsec Setup for Routing Between two Masquerading MikroTik Routers but doesn’t work and I change the config and I tried another examples but it is the same, I have done EoIP,PPtP, IPsec wit l2tp and work Ok so if some have done IPsec and work would be great if can show me the example o maybe some advice. thanks :smiley:
thanks and regards
Hi!
As far as I know you can’t have an IPSec server behind NAT, because that would force a change in packet headers and IPSec checksums won’t work.
BTW, I suggest you to read an updated documentation:
http://www.mikrotik.com/testdocs/ros/3.0
Bye!
I understood your point thanks :smiley:
