/ip services settings not working
I have recently expanded my local home network from 192.168.21/24 to 192.168/16.
I initially set my /ip services settings to include the new expanded range, so it says this:
[admin@MikroTik] > /ip service print
 #   NAME    PORT ADDRESS                                          CERTIF...
 0 XI telnet    23 xx.xx.xx.xx/xx
                  192.168.0.0/16
                  xx.xx.xx.xx/xx
 1   ftp       21 xx.xx.xx.xx/xx
                  192.168.0.0/16
                  xx.xx.xx.xx/xx
 2   www       xx.xx.xx.xx/xx
                  xx.xx.xx.xx/xx
                  192.168.0.0/16
 3   ssh       22 xx.xx.xx.xx/xx
                  192.168.0.0/16
                  xx.xx.xx.xx/xx
                  192.168.0.0/16
 4 XI www...   443                                                  none
 5 XI api     8728
 6 XI winbox  8291
 7 XI api...  8729                                                  none
However, if I try to login to the www or ssh interface from outside 192.168.21.xxx, I can still access the page (so there aren’t any firewall filter rules getting in the way) but I always get the error
“Authentication failed: invalid username or password.”
even though I know the password is correct.
If I login with the exact same password from 192.168.21.xxx it lets me in fine.
Any ideas how I fix this?
I now have, running the latest “bugfix” release (v6.38.7):
  1. I can’t edit any /ip firewall filter rules in the web interface,
  2. I can’t edit any /ip dns static entries in the web interface,
  3. I can’t even login via www or ssh from any machine that isn’t in what used to be my home network subnet.
This is all getting to be a real pain. How can I solve any of this lot? Please?
This used to be a wonderful router, but I’m starting to run out of patience as features keep gradually breaking.
Many thanks for any ideas at all that might possibly help.
Jules.
Hello Jules,
Stupid question here. When coming in from another subnet where it doesn’t work, are you hitting another router?? I’ve seen this with people playing with NAT rules. I can see no reason why you’d get an invalid UID/PWD combination from one door and not the other. Either it works or not. Period! Even if you had firewall filters, it would not give you a PWD error. Trick: when inside, open the log window and see if you have errors indicating a bad pwd combination or other access related error. If not, it gives credibility to my “other router” theory.
As you know, in IP/Services, the available-from field only indicate the allowed IPs and subnets.
BTW, I’m seeing public addresses “Me cringing” yuck! I hope you know what you’re doing :wink:
Ciao,
AC
I finally found the settings in /users. I had put a very tight set of subnets on the open services. If you fail that particular test, you apparently just get a login error.
Yes, I just noticed that one too. I carefully removed them from the other entries, and missed the last one. Ho hum… :slight_smile:
So I can now log in to the router remotely. Next problem is my L2TP/IPSec VPN server will only tell connecting clients that it has a /24 behind it (which is what all the examples show), and not the /16 that it really has.
Thanks! Jules.
