IP SETTINGS
Dear All Guru and Friends ,
Please check my IP settings In CCR12G , I am giving service by PPPoE
please check this Image …
Is it ok ? recently users complaining for slow browsing , Please advice me what is needful for me ,
Thanks In Advance for All Guru and Friends
Slow browsing could be rooted on lots of possible causes.
Default RouterOS IP settings are perfectly fine, you are not going to magically fix anything by blindly changing them.
Disable TCP Syncookies, accept redirects, and accept source route, (i.e. restore to its defaults) and see if it makes a difference.
If slow browsing persists, usual suspects are slow DNS, (due to slow DNS server, or Internet line related problems) or plain wrong configuration.
If that’s the case (plug a computer directly to the internet line and see if problems go away), I’d suggest resetting to defaults and starting over.
Yes Guru you are right, i did what you suggested , Unchecked/Disabled TCP Syncookies, accept redirects, and accept source route and now it is okay all over ,
Thank you so Much Pukka Guru :smiley:
Glad it helped!
Yes Too Much Glade , Love you Boss .
