Hello Guys ,
I’m a beginner when it comes to Mikrotik . I’m trying to run an IP tunnel between 2 RouterOS .
First Router is set up as PPTP and L2TP server and clients can connect and use the internet but what I want to do is to set up an IP tunnel so when clients are connected to the first server , their traffic is routed to the second router and then is sent to internet from there . In simple terms , I want my clients’ internet IP to be the second Router’s IP and all the traffic from first server to be sent to second server first , and then to the internet from there .
the two tunnels can ping each other but the first server is not sending the traffic to the second one . I think my issue is creating a route for this . I will paste the export logs below .
First Router ( PPTP & L2TP server ) export :
/interface ipip
add name=162.19.152.3 remote-address=162.19.152.3
add name=WAN
add name=LAN
add name=pptp ranges=10.8.0.0/23
/ppp profile
add change-tcp-mss=yes dns-server=8.8.8.8,8.8.4.4 \
local-address=pptp name=pptp only-one=yes \
remote-address=pptp use-encryption=yes
local-address=pptp name=l2tp only-one=yes \
/tool user-manager customer
set admin access="own-routers,own-users,own-profiles,own-limi\
ts,config-payment-gw"
/interface l2tp-server server
set default-profile=l2tp enabled=yes ipsec-secret=123456 \
use-ipsec=required
add interface=ether1 list=WAN
add list=LAN
/interface pptp-server server
set authentication=chap,mschap1,mschap2 default-profile=pptp \
enabled=yes
add address=185.141.105.65/24 interface=ether1 network=\
185.141.105.0
add address=185.141.105.65 interface=ether1 network=\
172.27.7.229
add address=11.11.11.2/29 interface=162.19.152.3 network=\
11.11.11.0
/ip cloud
set update-time=no
add action=accept chain=input dst-port=1723 protocol=tcp
add action=accept chain=input dst-port=500 protocol=udp
add distance=1 gateway=172.27.7.229
/ip service
set www disabled=yes
/ppp aaa
set interim-update=30s use-radius=yes
/radius
add address=51.xxx.xxx.188 secret=123456 service=ppp
/tool user-manager database
set db-path=user-manager
Second Router ( should accept traffic from first router and send it to internet ) export :
set [ find default-name=ether1 ] disable-running-check=no
/interface ipip
add name=185.141.105.65 remote-address=185.141.105.65
add name=WAN
add name=LAN
add list=LAN
add address=162.19.152.3/24 interface=ether1 network=162.19.152.0
add address=11.11.11.1/29 interface=185.141.105.65 network=11.11.11.0
/ip dhcp-client
add disabled=no interface=ether1
/ip service
/system identity
set name=RouterOS
I’m pretty sure the second router is not the issue and the configurations are OK . I think first Router is missing something . Maybe a route to the second one or a firewall rule . Can you please help me understand what is missing ?
Regards,
