Since upgrading to 6.12 on a RB2011 router, each time I VPN into the router using a PPTP session, the IP tunnel interface seems to disappear. It will break the tunnel to the other router, but I cannot add it back till I reboot the router. Seems to have mostly started after adding IPSec to the IP tunnel between routers. Not sure if this is a bug or a configuration issue. Attaching the config file as well. Any suggestions would be great. Thanks.
rb2011UiAS-plat.rsc (9.44 KB)
I had the same problem, ROS 6.12.
When a PPTP user connected, the ipip interface got renamed as that dynamic PPTP interface. I also run this ipip interface over IPSEC.
I had to remove that faulty dynamic interface and re-create the ipip tunnel, didn’t need to reboot.
That’s is exactly what I am seeing. Using IPSec as well over the tunnel. Sounds like a bug.
Same bug… alredy reported to MT crew…
