IP Tunnel only works between routers and not network
Hi.
I have one router in one companyt and other in another one. I created a IP tunnel.
Inside the routers (using Winbox) I am able to go to Tools > Ping and ping each other or any IP of each network. But when I go to any machine in each pont, I am NOT able to ping any other machine or router of the other network.
Basically, I am able to see each router from inside the router (so I guess the IP tunnel is working), but from any machine I am not able to ping other machine of the other side.
Do I need to set up anything extra ? make an extra setup in NAT ? Masquarade ? Firewall ?
cheers
Post your configs from the two routers? Could be a bunch of things.
OK… take a look
A
# nov/28/2013 15:53:57 by RouterOS 6.6
# software id = 8EY5-QI0I
set [ find default-name=ether1 ] name=ether1-Link1
set [ find default-name=ether2 ] name=ether2-master-local
set [ find default-name=ether3 ] master-port=ether2-master-local name=\
    ether3-slave-local
set [ find default-name=ether4 ] master-port=ether2-master-local name=\
    ether4-slave-local
set [ find default-name=ether5 ] master-port=ether2-master-local name=\
    ether5-slave-local
/interface ipip
add local-address=187.X.X.X name=IPIP-MACKGRAFE remote-address=187.Y.Y.Y
/interface vlan
add interface=ether1-Link1 l2mtu=1516 name=vLanTelefonica vlan-id=10
/interface pppoe-client
add add-default-route=yes dial-on-demand=yes disabled=no interface=\
    vLanTelefonica name=TelefoniaPPPoE password=XXXXXX user=\xxxxxxxxx
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m \
    mac-cookie-timeout=3d
add name=Pool-CV-Office ranges=192.168.30.10-192.168.30.254
add name=Pool-VPN ranges=172.0.0.2-172.0.0.10
add add-arp=yes address-pool=Pool-CV-Office always-broadcast=yes disabled=no \
    interface=ether2-master-local name=Dhcp-CV-Office
/port
set 0 name=serial0
/ppp profile
add local-address=172.0.0.1 name=profile1-vpn-cv only-one=yes remote-address=\
    Pool-VPN
/queue tree
add max-limit=4M name=LEVEL_A_UP parent=ether1-Link1 queue=default
add max-limit=4M name=LEVEL_A_DOWN parent=ether2-master-local queue=default
add max-limit=900k name=LEVEL_B_UP parent=ether1-Link1 queue=default
add max-limit=4M name=LEVEL_B_DOWN parent=ether2-master-local queue=default
add max-limit=900k name=LEVEL_C_UP parent=ether1-Link1 queue=default
add max-limit=4M name=LEVEL_C_DOWN parent=ether2-master-local queue=default
add name=VOIP_U packet-mark=VOIP parent=LEVEL_A_UP priority=1 queue=default
add name=VOIP_D packet-mark=VOIP parent=LEVEL_A_DOWN priority=1 queue=default
add name=ACK_U packet-mark=ACK parent=LEVEL_B_UP priority=1 queue=default
add name=ACK_D packet-mark=ACK parent=LEVEL_B_DOWN priority=1 queue=default
add name=DNS_U packet-mark=DNS parent=LEVEL_B_UP priority=2 queue=default
add name=DNS_D packet-mark=DNS parent=LEVEL_B_DOWN priority=2 queue=default
add name=UDP_U packet-mark=UDP parent=LEVEL_B_UP priority=3 queue=default
add name=UDP_D packet-mark=UDP parent=LEVEL_B_DOWN priority=3 queue=default
add name=ICMP_U packet-mark=ICMP parent=LEVEL_B_UP priority=4 queue=default
add name=ICMP_D packet-mark=ICMP parent=LEVEL_B_DOWN priority=4 queue=default
add name=HTTP_U packet-mark=HTTP parent=LEVEL_C_UP priority=1 queue=default
add name=HTTP_D packet-mark=HTTP parent=LEVEL_C_DOWN priority=1 queue=default
add name=HTTP_BIG_U packet-mark=HTTP_BIG parent=LEVEL_C_UP priority=2 queue=\
    default
add name=HTTP_BIG_D packet-mark=HTTP_BIG parent=LEVEL_C_DOWN priority=2 \
    queue=default
add name=OTHER_U packet-mark=OTHER parent=LEVEL_C_UP priority=3 queue=default
add name=OTHER_D packet-mark=OTHER parent=LEVEL_C_DOWN priority=3 queue=\
    default
/tool user-manager customer
add backup-allowed=yes disabled=no login=admin paypal-accept-pending=no \
    paypal-allowed=no paypal-secure-response=no permissions=owner \
    signup-allowed=no time-zone=-00:00
/interface l2tp-server server
set enabled=yes
/interface pptp-server server
set authentication=pap,chap,mschap1,mschap2 enabled=yes
add address=192.168.30.1/24 comment="default configuration" interface=\
    ether2-master-local network=192.168.30.0
add address=1.1.1.1/24 interface=IPIP-MACKGRAFE network=1.1.1.0
/ip arp
add address=192.168.30.5 comment="Imp OfficeJet276dw" interface=\
    ether2-master-local mac-address=88:51:FB:13:19:6C
add address=192.168.30.6 comment="Imp OfficeJet7500A" interface=\
    ether2-master-local mac-address=10:60:4B:DF:A7:44
add address=192.168.30.3 comment="Servidor DELL R420" interface=\
    ether2-master-local mac-address=F0:1F:AF:D3:61:48
add address=192.168.30.2 comment="Switch Dell PowerConnect 2428" interface=\
    ether2-master-local mac-address=D0:67:E5:C5:9C:3D
add address=192.168.30.7 comment=WirelessTelefonica interface=\
    ether2-master-local mac-address=78:54:2E:29:C7:2D
add address=192.168.30.4 comment="VoIP - CIP850" interface=\
    ether2-master-local mac-address=00:1A:3F:03:8D:A7
/ip dhcp-server alert
add alert-timeout=10m disabled=no interface=ether1-Link1
add alert-timeout=10m disabled=no interface=ether2-master-local
/ip dhcp-server lease
add address=192.168.30.5 client-id=1:88:51:fb:13:19:6c comment=\
    "Imp OfficeJet276dw" mac-address=88:51:FB:13:19:6C server=Dhcp-CV-Office
add address=192.168.30.6 client-id=1:10:60:4b:df:a7:44 comment=\
    "Imp OfficeJet7500A" mac-address=10:60:4B:DF:A7:44 server=Dhcp-CV-Office
add address=192.168.30.4 client-id=1:fa:75:a2:1c:bc:78 comment=\
    "VoIP - CIP850" mac-address=00:1A:3F:03:8D:A7 server=Dhcp-CV-Office
add address=192.168.30.103 client-id=1:bc:85:56:fc:9d:91 comment=\
    "Note CV-NOTE-01 Robson" mac-address=BC:85:56:FC:9D:91 server=\
    Dhcp-CV-Office
add address=192.168.30.125 client-id=1:0:1a:3f:10:89:29 comment=\
    "Ramal 25 Eng Paulo" mac-address=00:1A:3F:10:89:29 server=Dhcp-CV-Office
add address=192.168.30.120 client-id=1:0:1a:3f:10:84:b1 comment=\
    "Ramal 20 Jacineide" mac-address=00:1A:3F:10:84:B1 server=Dhcp-CV-Office
add address=192.168.30.128 client-id=1:0:15:65:48:54:69 comment=\
    "Ramal 28 Daniele" mac-address=00:15:65:48:54:69 server=Dhcp-CV-Office
add address=192.168.30.122 client-id=1:0:15:65:48:51:17 comment=\
    "Ramal 22 Pedro" mac-address=00:15:65:48:51:17 server=Dhcp-CV-Office
add address=192.168.30.123 client-id=1:0:15:65:48:51:43 comment=\
    "Ramal 23 Arq Fabio" mac-address=00:15:65:48:51:43 server=Dhcp-CV-Office
add address=192.168.30.121 client-id=1:0:15:65:48:53:7b comment=\
    "Ramal 21 Eng Milton" mac-address=00:15:65:48:53:7B server=Dhcp-CV-Office
add address=192.168.30.126 client-id=1:0:15:65:48:53:4d comment=\
    "Ramal 26 Sala Reuniao" mac-address=00:15:65:48:53:4D server=\
    Dhcp-CV-Office
add address=192.168.30.106 client-id=1:74:86:7a:f6:49:cf comment=\
    "Micro CV-003 Daniele" mac-address=74:86:7A:F6:49:CF server=\
    Dhcp-CV-Office
add address=192.168.30.105 client-id=1:74:86:7a:f6:48:ce comment=\
    "Micro CV-004 Cleide" mac-address=74:86:7A:F6:48:CE server=Dhcp-CV-Office
add address=192.168.30.102 client-id=1:74:86:7a:f6:49:bd comment=\
    "MIcro CV-002 Jacineide" mac-address=74:86:7A:F6:49:BD server=\
    Dhcp-CV-Office
add address=192.168.30.101 client-id=1:0:1f:c6:20:f6:b4 comment=\
    "Micro CV-006 Arq Fabio" mac-address=00:1F:C6:20:F6:B4 server=\
    Dhcp-CV-Office
add address=192.168.30.104 client-id=1:0:1d:60:dd:4f:80 comment=\
    "Micro CV-010 Pedro" mac-address=00:1D:60:DD:4F:80 server=Dhcp-CV-Office
add address=192.168.30.100 client-id=1:90:b1:1c:8f:eb:90 comment=\
    "Micro CV-001 Eng Paulo" mac-address=90:B1:1C:8F:EB:90 server=\
    Dhcp-CV-Office
add address=192.168.30.127 client-id=1:0:15:65:48:53:93 comment=\
    "Ramal 27 Cleide" mac-address=00:15:65:48:53:93 server=Dhcp-CV-Office
add address=192.168.30.0/24 comment="Default Civilterra" dns-server=\
    192.168.30.1 gateway=192.168.30.1 netmask=24
set allow-remote-requests=yes servers=192.168.30.3
add action=drop chain=input comment="Drop PING" in-interface=TelefoniaPPPoE \
    protocol=icmp
add action=drop chain=input comment="Drop common ports" dst-port=80,443,21,22 \
    in-interface=TelefoniaPPPoE protocol=tcp
/ip firewall mangle
add action=mark-connection chain=prerouting comment=DNS connection-state=new \
    new-connection-mark=DNS port=53 protocol=udp
add action=mark-packet chain=prerouting connection-mark=DNS new-packet-mark=\
    DNS passthrough=no
add action=mark-connection chain=postrouting connection-state=new \
add action=mark-packet chain=postrouting connection-mark=DNS new-packet-mark=\
    DNS passthrough=no
add action=mark-connection chain=prerouting comment=VOIP new-connection-mark=\
    VOIP port=5060,5061,10000-50000 protocol=udp
add action=mark-packet chain=prerouting connection-mark=VOIP new-packet-mark=\
    VOIP passthrough=no
add action=mark-connection chain=prerouting comment=UDP connection-state=new \
    new-connection-mark=UDP protocol=udp
add action=mark-packet chain=prerouting connection-mark=UDP new-packet-mark=\
    UDP passthrough=no
add action=mark-connection chain=prerouting comment=ICMP connection-state=new \
    new-connection-mark=ICMP protocol=icmp
add action=mark-packet chain=prerouting connection-mark=ICMP new-packet-mark=\
    ICMP passthrough=no
add action=mark-packet chain=postrouting connection-mark=ICMP \
    new-packet-mark=ICMP passthrough=no
add action=mark-packet chain=postrouting comment=ACK new-packet-mark=ACK \
    packet-size=0-123 passthrough=no protocol=tcp tcp-flags=ack
add action=mark-packet chain=prerouting new-packet-mark=ACK packet-size=0-123 \
add action=mark-connection chain=prerouting comment=HTTP connection-mark=\
    !HTTP_BIG connection-state=new new-connection-mark=HTTP port=80,443 \
    protocol=tcp
add action=mark-connection chain=prerouting connection-bytes=500000-0 \
    connection-mark=HTTP connection-rate=200k-100M new-connection-mark=\
    HTTP_BIG protocol=tcp
add action=mark-packet chain=prerouting connection-mark=HTTP_BIG \
    new-packet-mark=HTTP_BIG passthrough=no
add action=mark-packet chain=prerouting connection-mark=HTTP new-packet-mark=\
    HTTP passthrough=no
add action=mark-connection chain=prerouting comment=OTHER connection-mark=\
    no-mark new-connection-mark=OTHER
add action=mark-packet chain=prerouting connection-mark=OTHER \
    new-packet-mark=OTHER passthrough=no
add action=masquerade chain=srcnat comment="default configuration" \
    out-interface=TelefoniaPPPoE
add action=masquerade chain=srcnat src-address=172.0.0.0/24
add action=dst-nat chain=dstnat comment=Siecon dst-port=3155 in-interface=\
    TelefoniaPPPoE protocol=tcp to-addresses=192.168.30.3 to-ports=3155
add action=dst-nat chain=dstnat comment=VoIP dst-port=5060-5065 in-interface=\
    TelefoniaPPPoE protocol=udp to-addresses=192.168.30.4 to-ports=5060-5065
add action=dst-nat chain=dstnat comment=VoIP dst-port=20000-50000 \
    in-interface=TelefoniaPPPoE protocol=udp to-addresses=192.168.30.4 \
    to-ports=20000-50000
add action=dst-nat chain=dstnat comment="FTP Cameras" dst-port=2111 \
    in-interface=TelefoniaPPPoE protocol=tcp to-addresses=192.168.30.3 \
    to-ports=2111
/ip firewall service-port
set ftp disabled=yes ports=21,2111
set tftp disabled=yes
set irc disabled=yes
set h323 disabled=yes
set sip disabled=yes
add distance=1 dst-address=192.168.40.0/28 gateway=1.1.1.2
/ip service
set telnet disabled=yes
set ssh disabled=yes
set api disabled=yes
set winbox port=8899
set api-ssl disabled=yes
/ppp secret
add name=patrick profile=profile1-vpn-cv service=pptp
add name=pedro profile=profile1-vpn-cv service=pptp
add name=paulo profile=profile1-vpn-cv service=pptp
add name=cv service=pptp
add name=fabio profile=profile1-vpn-cv service=pptp
/system clock
set time-zone-name=America/Sao_Paulo
/system identity
set name=CV-OFFICE
/system lcd
set contrast=0 enabled=no port=parallel type=24x4
/system lcd page
set time disabled=yes display-time=5s
set resources disabled=yes display-time=5s
set uptime disabled=yes display-time=5s
set packets disabled=yes display-time=5s
set bits disabled=yes display-time=5s
set version disabled=yes display-time=5s
set identity disabled=yes display-time=5s
set TelefoniaPPPoE disabled=yes display-time=5s
set <pptp-paulo> disabled=yes display-time=5s
set ether1-Link1 disabled=yes display-time=5s
set ether2-master-local disabled=yes display-time=5s
set ether3-slave-local disabled=yes display-time=5s
set ether4-slave-local disabled=yes display-time=5s
set ether5-slave-local disabled=yes display-time=5s
set vLanTelefonica disabled=yes display-time=5s
set IPIP-MACKGRAFE disabled=yes display-time=5s
/system logging
add topics=l2tp
add topics=ipsec
/system ntp client
set enabled=yes primary-ntp=216.239.32.15 secondary-ntp=216.239.34.15
/system scheduler
add interval=30m name=runNoIp on-event=noip policy=\
    ftp,reboot,read,write,policy,test,winbox,password,sniff,sensitive,api \
    start-date=sep/10/2013 start-time=04:05:45
/system script
add name=noip policy=ftp,read,write,test,winbox,password,api source="\r\
    \n:local noipuser \"yyyyyyy\"\r\
    \n:local noippass \"xxxxxxxx\"\r\
    \n:local noiphost \"aaaaaaaaaaaaaaaaa\"\r\
    \n:local inetinterface \"TelefoniaPPPoE\"\r\
    \n\r\
    \n\r\
    \n#***********************************************************************\
    *************************\r\
    \n# Parameters\r\
    \n:local username \"yyyyyyy\"\r\
    \n:local password \"xxxxxxxx\"\r\
    \n:local hostname \"qqqqqqqqqqqqqq\"\r\
    \n\r\
    \n#availabe options: \"http\" or \"iface\"\r\
    \n# - http: will query an external server and discover you public ip (user\
    ful for NATted connections)\r\
    \n# - iface: will use the ip address assigned to the \$iface interface (se\
    e below)\r\
    \n\r\
    \n:local discoverBy \"iface\"\r\
    \n\r\
    \n# interface used to get ip address from (only if discoverBy = iface)\r\
    \n\r\
    \n:local iface \"TelefoniaPPPoE\"\r\
    \n\r\
    \n# current available services: \"dyndns\", \"noip\" and \"changeip\"\r\
    \n:local service \"noip\"\r\
    \n\r\
    \n# number of days to force an update if your IP did not change (helps kee\
    ping your account active)\r\
    \n:local forceUpdate 15\r\
    \n\r\
    \n# do not change below this unless you know what you are doing\r\
    \n\r\
    \n:local force\r\
    \n:global lastUpdate\r\
    \n:local currentIP\r\
    \n\r\
    \n:if (\$discoverBy=\"http\") do={ \r\
    \n   /tool fetch mode=http address=\"checkip.dyndns.org\" src-path=\"/\" d\
    st-path=\"/dyndns.checkip.html\"\r\
    \n   :local result [/file get dyndns.checkip.html contents]\r\
    \n   :local resultLen [:len \$result]\r\
    \n   :local startLoc [:find \$result \": \" -1]\r\
    \n   :set startLoc (\$startLoc + 2)\r\
    \n   :local endLoc [:find \$result \"</body>\" -1]\r\
    \n   :set currentIP [:pick \$result \$startLoc \$endLoc]\r\
    \n} else={\r\
    \n   :set currentIP [ /ip address get [find interface=\$iface disabled=no]\
    \_address ]\r\
    \n   :for i from=( [:len \$currentIP] - 1) to=0 do={\r\
    \n      :if ( [:pick \$currentIP \$i] = \"/\") do={ :set currentIP [:pick \
    \$currentIP 0 \$i] } \r\
    \n   }\r\
    \n}\r\
    \n\r\
    \n#get IP from DynDNS for our hostname\r\
    \n:local resolvedIP [:resolve \$hostname]\r\
    \n\r\
    \n# get current date in format mm/DD/YYYY\r\
    \n:local date [ /system clock get date ]\r\
    \n\r\
    \n# convert to YYYYMMDD\r\
    \n:local months (\"jan\",\"feb\",\"mar\",\"apr\",\"may\",\"jun\",\"jul\",\
    \"aug\",\"sep\",\"oct\",\"nov\",\"dec\");\r\
    \n:local month [ :pick \$date 0 3 ]; :local day [ :pick \$date 4 6 ]; :loc\
    al year [ :pick \$date 7 11 ];\r\
    \n:local mm ([ :find \$months \$month -1 ] + 1);\r\
    \n:if (\$mm < 10) do={ :set month (\"0\" . \$mm); } else={ :set month \$mm\
    ; }\r\
    \n:set date (\$year . \$month . \$day);\r\
    \n\r\
    \n:if ([ :typeof \$lastUpdate ]=[:nothing] || ((\$date-\$lastUpdate) >= \$\
    forceUpdate  && \$forceUpdate > 0)) do={ \r\
    \n   :set force true \r\
    \n}\r\
    \n\r\
    \n:put (\"Current IP: \$currentIP (\$discoverBy), Last update: \$lastUpdat\
    e\")\r\
    \n\r\
    \n# Determine if dyndns update is needed\r\
    \n:if ((\$currentIP != \$resolvedIP) || (\$force = true)) do={\r\
    \n    \r\
    \n    :if (\$service = \"dyndns\") do={\r\
    \n       /tool fetch user=\$username password=\$password mode=http address\
    =\"members.dyndns.org\" \\\r\
    \n            src-path=\"/nic/update\?hostname=\$hostname&myip=\$currentIP\
    \" dst-path=\"/output.txt\"\r\
    \n    }\r\
    \n    :if (\$service = \"noip\") do={\r\
    =\"dynupdate.no-ip.com\" \\\r\
    \n    }\r\
    \n    :if (\$service = \"changeip\") do={\r\
    =\"nic.changeip.com\" \\\r\
    \n    }\r\
    \n   \r\
    \n    :local result [/file get output.txt contents]\r\
    \n    :log info (\"dynamic-dns-updater: Service = \$service, Hostname = \$\
    hostname\")\r\
    \n    :log info (\"dynamic-dns-updater: CurrentIP = \$currentIP, Resolved \
    IP = \$resolvedIP\")\r\
    \n    :log info (\"dynamic-dns-updater: Update result: \".\$result)\r\
    \n    /ip dns cache flush\r\
    \n    :set lastUpdate \$date\r\
    \n}"
/tool mac-server
add interface=ether2-master-local
add interface=ether3-slave-local
add interface=ether4-slave-local
add interface=ether5-slave-local
/tool mac-server mac-winbox
B
# nov/28/2013 15:54:33 by RouterOS 6.6
# software id = VTS9-AKN6
    ether3-slave-local
    ether4-slave-local
    ether5-slave-local
add add-default-route=yes disabled=no interface=ether1-Link1 name=\
    TelefonicaPPPoE password=XXXXXX user=XXXXXX
/interface ipip
add local-address=187.Y.Y.Y name=IPIP-CV remote-address=187.X.X.X
add name=PoolMackGrafe ranges=192.168.40.10-192.168.40.254
add name=PoolVPN ranges=175.0.0.2-175.0.0.10
add address-pool=PoolMackGrafe disabled=no interface=ether2-master-local \
    name=DhcpMackGrafe
/port
set 0 name=serial0
/ppp profile
add change-tcp-mss=yes local-address=175.0.0.1 name=ProfileVPN \
    remote-address=PoolVPN
/system logging action
set 0 memory-lines=100
set 1 disk-lines-per-file=100
add address=192.168.40.1/24 comment="default configuration" interface=\
    ether2-master-local network=192.168.40.0
add address=1.1.1.2/24 interface=IPIP-CV network=1.1.1.0
/ip arp
add address=192.168.40.2 comment="Wireless D-Link" interface=\
    ether2-master-local mac-address=AC:F1:DF:27:F0:3C
add address=192.168.40.9 comment="Relogio Ponto" interface=\
    ether2-master-local mac-address=9C:45:63:01:E1:00
add address=192.168.40.3 client-id=1:90:2:a9:98:1e:f8 comment=Dvr \
    mac-address=90:02:A9:98:1E:F8 server=DhcpMackGrafe
add address=192.168.40.4 client-id=1:18:a9:5:15:74:cf comment=Impressora \
    mac-address=18:A9:05:15:74:CF server=DhcpMackGrafe
add address=192.168.40.0/24 gateway=192.168.40.1
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip dns static
add address=192.168.40.1 name=RouterMackGrafe
add action=drop chain=input comment="Drop PING" in-interface=TelefonicaPPPoE \
    protocol=icmp
add action=drop chain=input comment="Drop Common Ports" dst-port=80,443,21,22 \
    in-interface=TelefonicaPPPoE protocol=tcp
add action=dst-nat chain=dstnat comment=DVR dst-port=37777 in-interface=\
    TelefonicaPPPoE protocol=tcp to-addresses=192.168.40.3
add action=dst-nat chain=dstnat comment=DVR dst-port=80 in-interface=\
    TelefonicaPPPoE protocol=tcp to-addresses=192.168.40.3 to-ports=80
    out-interface=TelefonicaPPPoE to-addresses=0.0.0.0
add chain=srcnat dst-address=192.168.30.0/28 src-address=192.168.40.0/28
add distance=1 dst-address=192.168.30.0/28 gateway=IPIP-CV
/ip service
set www disabled=yes
/system clock
/system identity
set name=CV-MACK
/system lcd
/system lcd page
set TelefonicaPPPoE disabled=yes display-time=5s
set IPIP-CV disabled=yes display-time=5s
/system logging
add topics=ipsec
/system ntp client
/system scheduler
    start-date=sep/10/2013 start-time=05:00:00
/system script
add name=noip policy=ftp,read,test,winbox,sniff,api source="\r\
    \n:local noiphost \"wwwwwwww,\"\r\
    \n:local inetinterface \"TelefonicaPPPoE\"\r\
    \n\r\
    \n\r\
    \n# Parameters\r\
    \n:local hostname \"wwwwwwww\"\r\
    \n\r\
    e below)\r\
    \n\r\
    \n\r\
    \n\r\
    \n:local iface \"TelefonicaPPPoE\"\r\
    \n\r\
    \n\r\
    \n\r\
    \n\r\
    \n:local force\r\
    \n\r\
    \n} else={\r\
    \_address ]\r\
    \n   }\r\
    \n}\r\
    \n\r\
    \n\r\
    \n\r\
    ; }\r\
    \n\r\
    \n}\r\
    \n\r\
    e\")\r\
    \n\r\
    \n    \r\
    \n    }\r\
    \n    }\r\
    \n    }\r\
    \n   \r\
    hostname\")\r\
    \n}"
/tool mac-server
Two things:
On B:
is wrong… your gateway should be the IP of the remote side… NOT the interface.
Also… what exactly is the purpose of this rule on B’s NAT chains? I don’t think you really want to do this.:
When I change to de IP of the gateway, it says unreachable.
Is there a nice tutorial of IP tunel that I can follow ?
cheers
It should be whatever the address assigned to your ipip tunnel.. Eg 1.1.1.2 in your case.. I can poke at it if you give me remote access…
Sent from my SCH-I545 using Tapatalk
Efaden…
I will give you access… send me a MP with you email…
Thanks for the help;
cheers
Can’t PM on this forum. My email is the same as my username here @gmail.com
Assuming that this is still unanswered, I think this is a common issue with tunnel. Where inside network in Network A cannot ping the inside network in Network B.
You need to tell your MTK, on to exclude those private IPs in masquerading.
