Greetings,
Need help figuring out why I can not get get my IP tunnels or VPN to work on my router that has 2 networks using recursive routing for auto fail over.
I can ping the Tunnel IP from both sides but I get a failed ping from the remote router to the router with recursive routes setup on it and a good ping from recursive router to remote router.
If I disable the Recursive part of the router I am then able to ping and everything works great so I’m convinced the problem is with recursive part of routing.
Surely there’s a workaround for this.
