Hi All,
I would like to use two SXT 5 ac to stream IP TV’s up to 40 different IP’s and speeds up to 300mbs.
The distance between the two SXT 5 ac will not be over 10Km ..
How do i ‘‘speed up’’ the system (Header suppresion etc etc ) to allow smooth streams ..
Anyone have the solutions …?
I think if the fresnel zone is 100% clear and the environment is less noisy, the sxt will be fine for 2-3 km.
So i think you would need something else.
Depending on the budget.
The Fresnel is 100% clear, and there’s no problem with the bujet , BUT in fact its meant to be a TV IP system :
ie: Reception and distribution via an WIFI IP network .. If i allow around 300mbs for each unit transmitting i can share the reception via a gigabyte switch to around 25 clients (1 client looking at 1 tv station at any one time)..
That’s why im asking if i can reduce the latency … too enable smooth reception ..
I would like to reduce the cost of course as the system could get to 700 clients via 120 reception points…
