(Searched the forum, documentation, etc. Can’t find an existing solution.)
Creating a new chain is only possible through cli? (chain not exists = new one). GUI only shows existing ones as selectable chain or jump target.
Would be nice to be able to; create, delete and rename chains. Except ofcourse the fixed ones.
you can just write new chain value thus creating a new chain, or set new chain as jump target. While it is dropdown of values, you still can write in that field.
Ah, thanks for that. No matter, CLI works just as well
Anyway, my initial post is mainly meant as feature request for renaming chains. As far as i can see, if you wan to rename chains, it’s quite the hassle.
