IP67 and better - rugged enclosure
Hi to community again
Does anybody know manufacturers for the IP67(or higher) insulated outdoor enclosures with integrated antenna (gain not so important, it is close distance, SXT worked well before)?
I have location, very close to the sea with very harsh environment, temperature at day can reach up to 48C-50C, and at evening it is very humit, plus there is a lot of duststorms with dust mixed with salt.
Please let me know if you know any good manufacturer.
Thank you a lot.
One place to look would be here, in our Made for Mikrotik partner list:
http://www.mikrotik.com/mfm
normis, thanks a lot, i am already browsing there.
Sure i checked them, but just need feedback, and if someone used successfully some specific products.
