I have 3 different SSIDs: Home, Guest and IoT. The latter is separated into 2.4 and 5G while the former two are combined.
The iPad connects to all SSIDs, but only the 5GHz IoT has no internet.
My laptop, by comparision, will resolve internet fron all SSIDs when connected to each. I check the registration table to confirm which band the laptop was connected to.
I also have the same issues with my Grandstream VoIP phone, so don’t believe it’s an exclusive iPad issue.
> exp
# 2025-12-11 21:45:37 by RouterOS 7.20.2
# software id = xx
# model = C52iG-5HaxD2HaxD
# serial number = xx
add admin-mac=xx:A9:8A:xx:xx:xx auto-mac=no comment=BRIDGE name=bridge \
port-cost-mode=short
set [ find default-name=ether1 ] comment=WAN-LTE
set [ find default-name=ether2 ] comment=WAN-DHCP
set [ find default-name=ether3 ] comment=WAN-PPPoE
set [ find default-name=ether4 ] comment=LAN
set [ find default-name=ether5 ] comment=LAN
/interface wifi
set [ find default-name=wifi1 ] channel.band=5ghz-ax .frequency=2300-7300 \
.skip-dfs-channels=10min-cac .width=20/40/80mhz comment=Primary \
configuration.country="New Zealand" .hide-ssid=no .mode=ap .ssid=\
Home datapath.client-isolation=no disabled=no \
security.authentication-types=wpa2-psk,wpa3-psk .encryption=ccmp \
.sae-anti-clogging-threshold=0
set [ find default-name=wifi2 ] channel.band=2ghz-ax .skip-dfs-channels=all \
.width=20/40mhz-eC comment=Primary configuration.country="New Zealand" \
.hide-ssid=no .mode=ap .ssid=Home .station-roaming=no \
datapath.client-isolation=no disabled=no security.authentication-types=\
wpa2-psk,wpa3-psk .encryption=ccmp .sae-anti-clogging-threshold=0
add comment=Guest configuration.mode=ap .ssid="Guests" \
datapath.client-isolation=yes disabled=no mac-address=xx:A9:8A:xx:xx:xx \
master-interface=wifi1 name=wifi3 security.authentication-types=\
master-interface=wifi2 name=wifi4 security.authentication-types=\
add comment=IoT configuration.hide-ssid=yes .mode=ap .ssid=iot5 \
master-interface=wifi1 name=wifi5 security.authentication-types=\
wpa2-psk,wpa3-psk .encryption=ccmp .ft=no .ft-over-ds=no
add comment=IoT configuration.hide-ssid=yes .mode=ap .ssid=iot2 \
master-interface=wifi2 name=wifi6 security.authentication-types=\
wpa-psk,wpa2-psk .encryption=ccmp
/interface vlan
add comment="VLAN 10 - DHCP" interface=ether2 name=DHCP_v10 vlan-id=10
add comment="VLAN 10 - PPPoE" interface=ether3 name=vlan10 vlan-id=10
/interface pppoe-client
add add-default-route=yes comment="WAN PPPoE" interface=vlan10 name=pppoe-1 \
use-peer-dns=yes user=username
/interface ethernet switch
set 0 cpu-flow-control=yes
add comment=defconf name=WAN
add comment=defconf name=LAN
add comment=2.4G-IoT name=dhcp_pool1 ranges=10.10.10.2-10.10.10.254
add comment=2.4G-Guest name=dhcp_pool2 ranges=10.10.20.2-10.10.20.254
add comment=5G-Guest name=dhcp_pool3 ranges=10.10.20.2-10.10.20.254
add comment=5G-IoT name=dhcp_pool4 ranges=10.10.10.2-10.10.10.254
add comment=Primary name=defconf_dhcp ranges=10.10.0.2-10.10.0.254
add name=vpn ranges=192.168.89.2-192.168.89.255
add address-pool=defconf_dhcp comment=Primary interface=bridge name=defconf
add address-pool=dhcp_pool1 comment="2.4G IoT" interface=wifi6 lease-time=1d \
name=dhcp1
# Interface not running
add address-pool=dhcp_pool2 comment="2.4G Guest" interface=wifi4 lease-time=1d \
name=dhcp2
add address-pool=dhcp_pool3 comment="5G Guest" interface=wifi3 lease-time=1d \
name=dhcp3
add address-pool=dhcp_pool4 comment="5G IoT" interface=wifi5 lease-time=1d \
name=dhcp4
/ppp profile
add dns-server=1.1.1.1 local-address=192.168.89.1 name=vpn remote-address=vpn \
use-encryption=yes
set *FFFFFFFE use-ipv6=no
/routing bgp template
set default as=65530
add bridge=bridge comment=defconf interface=ether4 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=ether5 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=wifi1 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=wifi2 internal-path-cost=10 \
path-cost=10
set discover-interface-list=all
/ipv6 settings
set disable-ipv6=yes max-neighbor-entries=15360
/interface l2tp-server server
set default-profile=vpn enabled=yes one-session-per-host=yes use-ipsec=yes
add comment=LTE interface=ether1 list=WAN
add comment=PPPoE interface=pppoe-1 list=WAN
add comment=DHCP interface=DHCP_v10 list=WAN
add address=10.10.10.1/24 comment="2.4G IoT" interface=wifi6 network=\
10.10.10.0
add address=10.10.20.1/24 comment="5G Guest" interface=wifi3 network=\
10.10.20.0
add address=10.10.20.1/24 comment="2.4G Guest" interface=wifi4 network=\
10.10.20.0
add address=10.10.10.1/24 comment="5G IoT" interface=wifi5 network=10.10.10.0
add address=10.10.0.1/24 comment=Primary interface=bridge network=10.10.0.0
/ip cloud
set ddns-enabled=yes ddns-update-interval=5m
/ip cloud advanced
set use-local-address=yes
/ip dhcp-client
# Interface not active
add address=10.10.0.0/24 comment="Main Subnet" dns-server=\
208.67.222.222,208.67.220.220 gateway=10.10.0.1
add address=10.10.10.0/24 comment="IoT Subnet" dns-server=1.1.1.1,1.0.0.1 \
gateway=10.10.10.1
add address=10.10.20.0/24 comment="Guest Subnet" dns-server=\
208.67.222.222,208.67.220.220 gateway=10.10.20.1
set allow-remote-requests=yes cache-size=20480KiB
/ip dns adlist
add ssl-verify=no url=\
https://raw.githubusercontent.com/StevenBlack/hosts/master/hosts
/ip dns static
add address=10.10.0.1 comment=defconf name=router.lan type=A
"Allow trusted subnet and wireguard for config" in-interface-list=LAN
established,related,untracked
add action=drop chain=forward comment="2G IoT Isolation" in-interface=wifi6 \
out-interface=bridge
add action=drop chain=forward comment="5G IoT Isolation" in-interface=wifi5 \
add action=drop chain=forward comment="2G Guest Isolation" in-interface=wifi4 \
add action=drop chain=forward comment="5G Guest Isolation" in-interface=wifi3 \
add action=accept chain=input comment="allow IPsec NAT" dst-port=4500 \
protocol=udp
add action=accept chain=input comment="allow IKE" dst-port=500 protocol=udp
add action=accept chain=input comment="allow l2tp" dst-port=1701 protocol=udp
add action=accept chain=input comment="allow remote connection for Winbox" \
dst-port=8291 protocol=tcp src-address-list=Management
in-interface-list=!LAN
invalid
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=\
out,none out-interface-list=WAN
add action=dst-nat chain=dstnat comment="OpenDNS [tcp]" dst-port=53 protocol=\
tcp to-addresses=208.67.222.222 to-ports=53
add action=dst-nat chain=dstnat comment="OpenDNS [udp]" dst-port=53 protocol=\
udp to-addresses=208.67.222.222 to-ports=53
add action=masquerade chain=srcnat comment="masq. vpn traffic" src-address=\
192.168.89.0/24
/ip ipsec profile
/ip service
set ftp disabled=yes
set telnet disabled=yes
set www disabled=yes
set ssh port=2206
set api disabled=yes
set api-ssl disabled=yes
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
"defconf: drop everything else not coming from LAN" in-interface-list=!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
/ppp secret
add name=vpn profile=vpn service=l2tp
/system clock
set time-zone-name=Pacific/Auckland
/system clock manual
set time-zone=+12:00
/system identity
set name="Home Router AX"
/system ntp client
set enabled=yes
/system ntp server
set broadcast=yes enabled=yes manycast=yes multicast=yes
/system ntp client servers
add address=time.cloudflare.com
add address=pool.ntp.org
/system scheduler
add comment="5G Enable" disabled=yes interval=1d name=Enable_WiFi1 on-event=\
"/interface enable wifi1" policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
start-date=2025-06-22 start-time=06:30:00
add comment="2G Enable" disabled=yes interval=1d name=Enable_WiFi2 on-event=\
"/interface enable wifi2" policy=\
add comment="5G Disable" disabled=yes interval=1d name=Disable_WiFi1 on-event=\
"/interface disable wifi1" policy=\
start-date=2025-06-22 start-time=23:00:00
add comment="2G Disable" disabled=yes interval=1d name=Disable_WiFi2 on-event=\
"/interface disable wifi2" policy=\
add comment="Disable Overnight LTE Data" disabled=yes interval=1d name=\
Disable_LTE/Ether1 on-event="/interface disable ether1" policy=\
start-date=2025-08-12 start-time=22:30:00
add comment="Enable Daytime LTE Data" disabled=yes interval=1d name=\
Enable_LTE/Ether1 on-event="/interface enable ether1" policy=\
start-date=2025-08-13 start-time=06:00:00
/tool mac-server
/tool mac-server mac-winbox
/tool romon
set enabled=yes
