I was in a situation to update the password for an existing saved login. While I could save a new login, I could not delete an existing saved login credentials.
In Android app, I could click an icon next the saved login and then I can “edit” or “delete”. This option is not available in iPad OS app. I use the latest version 1.2.10 of the app. Am I missing something?
Btw, I am probably color blind. So, the “edit” icon isn’t visible clearly with dark mode turned off. It is somewhat visible in the screenshot that I attached, though. With dark-mode turned on (with inverted color scheme), it becomes clearly visible (as can be seen in the screenshot attached by @normis).
We can still click at the place where “edit” icon is supposedly placed and we can still edit the saved item.
