Ipconfig and Quee
Hi there , Im going to try and explain as clear as possible.
i have a fiber line at address 1( parents place)
address 1 i have a Normal LHG configured to share the inet.
LHG 1 connected to LHG2 with a 172 range
Then from there i have a omni sharing inet with xxx
wlan is 172 range
ethernet 192 range
At the one friend place where all the equipment is that’s running like a back bone,
then from him to me i run a normal cat5 to provide me with inet , i configure a tenda Wi-Fi that will give out normal 192 range.
from friend to me is a rb2011 at he`s place wich the ports are bridge because im unsure how to configure each port.
anyway the main issue i have is to give other people access to inet via cat5 and wifi i need to plug it in on my normal old-school 16port switch unmanaged , how do i create a quee for them if I’m giving them a static ip on the Wi-Fi router and on what RB do I ip place the quee , because what i do is connect the Wi-Fi and make the gateway address the LHG2 .
egg: my Wi-Fi route will be 192.168.1.xxx, then second Wi-Fi 192.168.2.xxx
if any one out there is able to help i would much apricate or send a link to some videos if you don’t want to make n long explanation.
thanks in advance and sorry for such a long msg
