Greetings from Chicago:
Do you have howto documentation for configuring Mikrotik to send ipfix stats to a collector on the local network. Also is a there presentation tool that will let us review the summary to give us info in a format similar to following.
I read the link, it looks like we should be able to format the output compliant with IPFIX and send to the collector -
Do you know if someone has done that already?
Also does this router support it
Mikrotik RB260GS (CSS106-5G-1S) small SOHO Switch 5x Gigabit Ethernet,
version 9 - a new format which can be extended with new fields and record types thank’s to its template-style design
add dst-address=192.168.0.2 port=2055 version=9
