IPFIX PRTG shows public ip rather than internal
I upgraded to the latest RouterOS and since then the IPFIX Netflow using PRTG is showing the public IP for lots of the connections rather than the internal IP. I then removed the IPFIX sensor in PRTG and re added it but have the same results.
I need to be able to see what IP is using the bandwidth easily and this has done a great job before now. Any ideas?
